주요 콘텐츠로 건너뛰기
Roccat Vulcan II Mini Air Backplate Replacement
필요한 것
  1. Roccat Vulcan II Mini Air Backplate Replacement, Backplate: 1 단계, 이미지 3개 중 1개 Roccat Vulcan II Mini Air Backplate Replacement, Backplate: 1 단계, 이미지 3개 중 2개 Roccat Vulcan II Mini Air Backplate Replacement, Backplate: 1 단계, 이미지 3개 중 3개
    • Flip your keyboard over so the bottom is facing up.
    • Before you begin, gently peel the sticker in the center and rubber strip that runs along the bottom and top to expose all the screws.
    • Be sure to save the rubber screw covers for reinstallation when you're finished.
    • Use a Phillips #0 screwdriver to remove all of the screws from the back plate.
    • Keep the screws for the replacement.
  2. Roccat Vulcan II Mini Air Backplate Replacement: 2 단계, 이미지 3개 중 1개 Roccat Vulcan II Mini Air Backplate Replacement: 2 단계, 이미지 3개 중 2개 Roccat Vulcan II Mini Air Backplate Replacement: 2 단계, 이미지 3개 중 3개
    • With the screws removed the backplate will be loose and can be removed. Be careful, as it is still attached to the switch plate with ribbon cables so don't pull it.
    • Gently lift the switch plate from the backplate, setting them next to each other with the ribbon cables facing upwards.
    • Use a spudger or a clean fingernail to flip up the locking flaps of the two ZIF connectors using the widest tool possible to avoid damaging the delicate hinge pins.
    • This is the unlocked position.
    • Use tweezers or your fingers to gently pull the cable out of its socket by the pull tab.
    • You could damage the cable by gripping it directly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Ethan Mueller
회원 가입일: 10/22/24
162 평판
안내서 1개를 작성함
UMass Dartmouth, Team 3-3, Santin Fall 2024 UMass Dartmouth, Team 3-3, Santin Fall 2024 회원
UMASSD-SANTIN-F24S3G3
4 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 26
전체 시간: 328
