주요 콘텐츠로 건너뛰기
Roccat Vulcan II Mini Air Keycap Replacement
필요한 것
  1. Roccat Vulcan II Mini Air Keycap Replacement, Keycap: 1 단계, 이미지 2개 중 1개 Roccat Vulcan II Mini Air Keycap Replacement, Keycap: 1 단계, 이미지 2개 중 2개
    • Use a keycap puller or your fingers to gently pull off the keycap.
    • Avoid using excessive force to avoid damaging the switch.
    • Lift the keycap evenly and straight up from the keyboard.
    • If you are not using a keycap puller you may need to wiggle the cap slightly to loosen it.
    • Clean the keyboard using an air blower and a soft brush to remove any debris or dust between the switches.
    • Align the new keycap with the switch stem, ensuring the small cross-shaped hole at the bottom of the keycap matches the stem. Once aligned, gently press down on the keycap until it snaps securely into place.
    • You'll hear a soft "click" sound or feel resistance when it’s properly seated.
    • Be careful with larger keys (like the spacebar or enter key) as they might have additional stabilizer clips.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Elizabeth
회원 가입일: 10/24/24
226 평판
안내서 1개를 작성함
UMass Dartmouth, Team 3-3, Santin Fall 2024 UMass Dartmouth, Team 3-3, Santin Fall 2024 회원
UMASSD-SANTIN-F24S3G3
4 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 29
전체 시간: 355
