주요 콘텐츠로 건너뛰기
Rocketfish RF-WSP313 Speaker Replacement
필요한 것
  1. Rocketfish RF-WSP313 Speaker Replacement, Speaker: 1 단계, 이미지 1/1
    • Using the metal spudger, remove the outer cap from the top of the device.
  2. Rocketfish RF-WSP313 Speaker Replacement: 2 단계, 이미지 1/1
    • Using a Phillips # 1 screwdriver, remove the four 1.1 cm flathead screws attaching the metal ring to the top of the device.
  3. Rocketfish RF-WSP313 Speaker Replacement: 3 단계, 이미지 1/1
    • Remove the ring and set aside.
  4. Rocketfish RF-WSP313 Speaker Replacement: 4 단계, 이미지 1/1
    • Using the metal spudger, remove the cap from the bottom of the device.
  5. Rocketfish RF-WSP313 Speaker Replacement: 5 단계, 이미지 1/1
    • Using a Phillips # 1 screwdriver, remove the four 1.1 sm screws attaching the metal ring to the bottom of the device.
  6. Rocketfish RF-WSP313 Speaker Replacement: 6 단계, 이미지 1/1
  7. Rocketfish RF-WSP313 Speaker Replacement: 7 단계, 이미지 1/1
    • Using a Phillips # 1 screwdriver, remove the four 1 cm screws from the outside panel. You will do this for each panel; it does not matter which side you start with.
  8. Rocketfish RF-WSP313 Speaker Replacement: 8 단계, 이미지 1/1
    • Using the metal spudger, pry off the side panel. Repeat this step on the other side panel.
  9. Rocketfish RF-WSP313 Speaker Replacement: 9 단계, 이미지 1/1
    • Using a Phillips #1 screwdriver, remove the four 1.1 cm flathead screws from the side of the device. Repeat this step on the other side of the device.
  10. Rocketfish RF-WSP313 Speaker Replacement: 10 단계, 이미지 1/2 Rocketfish RF-WSP313 Speaker Replacement: 10 단계, 이미지 2/2
    • Using the metal spudger, open the device.
  11. Rocketfish RF-WSP313 Speaker Replacement: 11 단계, 이미지 1/2 Rocketfish RF-WSP313 Speaker Replacement: 11 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using your fingers (or a pair of tweezers), disconnect the speaker cord from its socket.
  12. Rocketfish RF-WSP313 Speaker Replacement: 12 단계, 이미지 1/1
    • Using a Phillips #1 screwdriver, remove the four 1.2 cm pan head screws surrounding the speaker.
  13. Rocketfish RF-WSP313 Speaker Replacement: 13 단계, 이미지 1/1
    • Remove the speaker from the device.
결론
Kara Falknor
회원 가입일: 01/25/17
101 평판
안내서 1개 작성함
Washington State, Team 1-50, Staggers Spring 2017 Washington State, Team 1-50, Staggers Spring 2017 회원
WSU-STAGGERS-S17S1G50
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 558
