주요 콘텐츠로 건너뛰기
Roku 2 Case Replacement
필요한 것
  1. Roku 2 Case Replacement, Case: 1 단계, 이미지 1/1
    • Heat up the iOpener for 30 seconds in the microwave and place across rubber pads on the back of the device.
    • Note: It may take several heats, left for a minute at a time, to loosen the glue.
  2. Roku 2 Case Replacement: 2 단계, 이미지 1/1
    • Gently use the plastic opening tool to pry the rubber pads off.
  3. Roku 2 Case Replacement: 3 단계, 이미지 1/1
    • Use the 000 phillips to remove the screws found under all four of the rubber pads.
  4. Roku 2 Case Replacement: 4 단계, 이미지 1/1
    • Gently remove the under side of the device.
  5. Roku 2 Case Replacement: 5 단계, 이미지 1/1
    • Remove the middle component that is held in place by the top and bottom of the device.
  6. Roku 2 Case Replacement: 6 단계, 이미지 1/1
    • Remove the cover over the A/V ports on the front of the device.
  7. Roku 2 Case Replacement: 7 단계, 이미지 1/1
    • Remove the board from the plastic enclosure and put the board into the replacement enclosure.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Eric Rawls
회원 가입일: 08/24/15
360 평판
안내서 2개 작성하였습니다
USF Tampa, Team 1-5, Sullivan Fall 2015 USF Tampa, Team 1-5, Sullivan Fall 2015 회원
USFT-SULLIVAN-F15S1G5
3 회원들
안내서 7개 작성하였습니다
댓글 한 개
cause mine get’s hot and it’s slow as !&&*
brian price - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 733
