주요 콘텐츠로 건너뛰기
Roku 2 Remote Battery Replacement
필요한 것
  1. Roku 2 Remote Battery Replacement, Remote Battery: 1 단계, 이미지 1/1
    • Turn over remote and press down on tab to remove.
  2. Roku 2 Remote Battery Replacement: 2 단계, 이미지 1/1
    • Remove batteries
  3. Roku 2 Remote Battery Replacement: 3 단계, 이미지 1/1
    • Place the new batteries into the remote. Make sure the positive terminal is facing the positive terminal of the slot. Similarly the negative terminal should be touching the negative terminal. If done right the batteries should be facing opposite directions of each other.
    • Insert Roku tab back on to its slot.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Alex Saltos
회원 가입일: 08/27/15
526 평판
안내서 2개 작성하였습니다
USF Tampa, Team 1-5, Sullivan Fall 2015 USF Tampa, Team 1-5, Sullivan Fall 2015 회원
USFT-SULLIVAN-F15S1G5
3 회원들
안내서 7개 작성하였습니다
댓글 한 개
Now Roku remotes comes with various features. To access these features you have to pair the Roku remote. If you want any help regarding Roku remote go to website: Roku Com Link
Katherine Melinda - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 21
전체 시간: 6,483
