주요 콘텐츠로 건너뛰기
Roku 2 Remote Control Buttons Replacement
필요한 것
  1. Roku 2 Remote Control Buttons Replacement, Remote Battery: 1 단계, 이미지 1/1
    • Turn over remote and press down on tab to remove.
  2. Roku 2 Remote Control Buttons Replacement: 2 단계, 이미지 1/1
    • Remove batteries
  3. Roku 2 Remote Control Buttons Replacement: 3 단계, 이미지 1/1
    • Place the new batteries into the remote. Make sure the positive terminal is facing the positive terminal of the slot. Similarly the negative terminal should be touching the negative terminal. If done right the batteries should be facing opposite directions of each other.
    • Insert Roku tab back on to its slot.
  4. Roku 2 Remote Control Buttons Replacement, Remote Control Buttons: 4 단계, 이미지 1/1
    • After removing the batteries, use a #000 Phillips to remove the screw.
  5. Roku 2 Remote Control Buttons Replacement, Pry the remote open: 5 단계, 이미지 1/1
    • Use a plastic opening tool to pry open the remote.
  6. Roku 2 Remote Control Buttons Replacement: 6 단계, 이미지 1/1
    • Continue along the top of the remote to lift it off the remote.
    • Lift the top of the remote off very carefully so that board doesn't fall.
  7. Roku 2 Remote Control Buttons Replacement, Replace the buttons: 7 단계, 이미지 1/1
    • Identify the buttons to be replaced and take them out.
결론
다른 10명이 해당 안내서를 완성하였습니다.
Alex Saltos
회원 가입일: 08/27/15
526 평판
안내서 2개 작성하였습니다
USF Tampa, Team 1-5, Sullivan Fall 2015 USF Tampa, Team 1-5, Sullivan Fall 2015 회원
USFT-SULLIVAN-F15S1G5
3 회원들
안내서 7개 작성하였습니다
댓글 8개
Well, hmmm; why is it there is actually no screws in mine nor the ones for others. None in mine and 4 in the ones for volume control over tlc tv's etc??
Junebug - 답글
I use my mobile to control and I download it at: https://apps.apple.com/us/app/roku-remot...
It's better for me
donor - 답글
And where exactly do you buy the new buttons ??
bonzo dog - 답글
And just where exactly do you buy the new buttons??
bonzo dog - 답글
So I tried every trick to get my remote to work (all the Youtube tricks). Found this, took the remote apart and got it to work with the cover off. New remote coming in two days but I just wanted to say thanks cause now I can watch TV while I wait for my new remote to arrive!!!!!!!!!!! I would not advise using the remote with the cover off, just sayin, but I am lol….
Joe MacRitchie - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 38
30일 전: 164
전체 시간: 54,046
