주요 콘텐츠로 건너뛰기
Roku 2 Roku 2 Motherboard Replacement
필요한 것
  1. Roku 2 Roku 2 Motherboard Replacement, Roku 2 Motherboard: 1 단계, 이미지 1/1
    • Heat up the iOpener for 30 seconds in the microwave and place across rubber pads on the back of the device.
    • It may take multiple heats, left for a minute at a time, to properly loosen the glue.
  2. Roku 2 Roku 2 Motherboard Replacement: 2 단계, 이미지 1/1
    • Gently use the plastic opening tool to pry the rubber pads off.
  3. Roku 2 Roku 2 Motherboard Replacement: 3 단계, 이미지 1/1
    • Remove the four Phillips #000 screws from the bottom of the case.
  4. Roku 2 Roku 2 Motherboard Replacement: 4 단계, 이미지 1/1
    • Gently remove the under side of the device.
  5. Roku 2 Roku 2 Motherboard Replacement: 5 단계, 이미지 1/1
    • Remove the middle component that is held in place by the top and bottom of the device.
  6. Roku 2 Roku 2 Motherboard Replacement: 6 단계, 이미지 1/1
    • Remove the cover over the A/V ports on the front of the device.
  7. Roku 2 Roku 2 Motherboard Replacement: 7 단계, 이미지 1/1
    • Remove the board from the plastic enclosure.
결론
Eric Rawls
회원 가입일: 08/24/15
360 평판
안내서 2개 작성하였습니다
USF Tampa, Team 1-5, Sullivan Fall 2015 USF Tampa, Team 1-5, Sullivan Fall 2015 회원
USFT-SULLIVAN-F15S1G5
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 1,147
