소개
If you have already tried restarting and re-pairing your remote and it is still not working, you may need to replace the motherboard.
필요한 것
Flip the remote over so that the buttons are facing down and the end with the wrist strap is nearest your right hand.
Unscrew one 7 mm Phillips #0 screw from the center of the battery compartment.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 4개
Thanks for the tutorial. Any idea where I can buy the motherboard for the Roku 3 remote?
Where can I buy a Roku 3 remote motherboard replacement?
Hi, wondered if you had any luck locating a motherboard for the Roku 3? Thanks!
