주요 콘텐츠로 건너뛰기
Roku 4 Motherboard Replacement
필요한 것
  1. Roku 4 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • Place the Roku 4 face-down on a table. The rubber sticker should be facing you.
  2. Roku 4 Motherboard Replacement: 2 단계, 이미지 1/1
    • Starting at one corner of the device, pull the rubber sticker back toward the opposite corner of the device carefully to reveal the underlying screws.
    • Completely remove the rubber sticker to reveal the underlying screws on the device.
    • Place the rubber sticker facing up on the table to preserve its adhesiveness. It will be needed to reassemble the device.
  3. Roku 4 Motherboard Replacement: 3 단계, 이미지 1/1
    • Turn the Phillips PH1 screwdriver counterclockwise to unscrew all 4 of the 12.0 mm screws.
    • Store the screws in a safe place, such as on a magnetic project mat, so they do not get lost before reassembly.
  4. Roku 4 Motherboard Replacement: 4 단계, 이미지 1/2 Roku 4 Motherboard Replacement: 4 단계, 이미지 2/2
    • Turn the device over so you can see the "4" on the top cover.
  5. Roku 4 Motherboard Replacement: 5 단계, 이미지 1/2 Roku 4 Motherboard Replacement: 5 단계, 이미지 2/2
    • Wedge a plastic opening tool into the seam between the top cover and bottom casing of the device and create a gap.
    • Prying open the device is quite difficult and requires a large amount of force. Use caution to avoid breaking the device or hurting yourself.
  6. Roku 4 Motherboard Replacement: 6 단계, 이미지 1/1
    • After you have created a gap large enough to fit your fingers between, gently lift up the top cover to open the device and reveal the motherboard.
    • The motherboard should still be attached to the underside of the top cover by a red wire, a blue wire, and a black wire.
  7. Roku 4 Motherboard Replacement: 7 단계, 이미지 1/3 Roku 4 Motherboard Replacement: 7 단계, 이미지 2/3 Roku 4 Motherboard Replacement: 7 단계, 이미지 3/3
    • To begin removing the motherboard from the plastic casing, pinch the black plastic clip and gently pull upward.
    • Once you feel the motherboard begin to loosen from the plastic casing, pull it upward to remove it completely.
  8. Roku 4 Motherboard Replacement: 8 단계, 이미지 1/3 Roku 4 Motherboard Replacement: 8 단계, 이미지 2/3 Roku 4 Motherboard Replacement: 8 단계, 이미지 3/3
    • Peel back the black adhesive strip that attaches the blue wire to the motherboard.
    • Repeat this step for the strip that attaches the black and red wires to the motherboard.
  9. Roku 4 Motherboard Replacement: 9 단계, 이미지 1/3 Roku 4 Motherboard Replacement: 9 단계, 이미지 2/3 Roku 4 Motherboard Replacement: 9 단계, 이미지 3/3
    • Using a soldering iron, desolder the blue, red, and black wires from the motherboard.
    • Consult iFixit's Soldering Skills guide to safely use the soldering iron.
    • The motherboard should now be completely disconnected from the top cover of the device.
결론
Follow these steps in the reverse order to reassemble your device.
다른 7명이 해당 안내서를 완성하였습니다.
Bradley Rains
회원 가입일: 03/26/17
157 평판
안내서 1개 작성함
Baylor, Team S5-G4, Williams Spring 2017 Baylor, Team S5-G4, Williams Spring 2017 회원
BU-WILLIAMS-S17S5G4
3 회원들
안내서 4개 작성하였습니다
댓글 4개
Thank you, have you upgraded to a new 2019 Ultra model yet?
Allan Landwer - 답글
Soldering the fan to the mobo is a suck move. However, they used a good quality bearing-less fan.
smbrannon - 답글
Can you gve me areson? will it suck out the perfomance?
Kind-hearted, spirited Man -
Because it makes replacing the motherboard more difficult. For a few cents more, they could have placed a small connector inline between the fan and motherboard, making disconnecting the fan and top case really easy.
Bob Reed - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 8
30일 전: 38
전체 시간: 5,482
