소개
The motherboard is a piece of circuitry that serves as the device's circuit board. The primary internal parts of the Roku 4 are all attached to the motherboard. This disassembly guide will serve as the core to further internal disassembly, as you will be able to fix other parts from here.
필요한 것
Follow these steps in the reverse order to reassemble your device.
다른 7명이 해당 안내서를 완성하였습니다.
댓글 4개
Thank you, have you upgraded to a new 2019 Ultra model yet?
Soldering the fan to the mobo is a suck move. However, they used a good quality bearing-less fan.
Can you gve me areson? will it suck out the perfomance?
