주요 콘텐츠로 건너뛰기
Roku 4 Motherboard Replacement
필요한 것
  1. Roku 4 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • Place the Roku 4 face-down on a table. The rubber sticker should be facing you.
  2. Roku 4 Motherboard Replacement: 2 단계, 이미지 1/1
    • Starting at one corner of the device, pull the rubber sticker back toward the opposite corner of the device carefully to reveal the underlying screws.
    • Completely remove the rubber sticker to reveal the underlying screws on the device.
    • Place the rubber sticker facing up on the table to preserve its adhesiveness. It will be needed to reassemble the device.
  3. Roku 4 Motherboard Replacement: 3 단계, 이미지 1/1
    • Turn the Phillips PH1 screwdriver counterclockwise to unscrew all 4 of the 12.0 mm screws.
    • Store the screws in a safe place, such as on a magnetic project mat, so they do not get lost before reassembly.
  4. Roku 4 Motherboard Replacement: 4 단계, 이미지 1/2 Roku 4 Motherboard Replacement: 4 단계, 이미지 2/2
    • Turn the device over so you can see the "4" on the top cover.
  5. Roku 4 Motherboard Replacement: 5 단계, 이미지 1/2 Roku 4 Motherboard Replacement: 5 단계, 이미지 2/2
    • Wedge a plastic opening tool into the seam between the top cover and bottom casing of the device and create a gap.
    • Prying open the device is quite difficult and requires a large amount of force. Use caution to avoid breaking the device or hurting yourself.
  6. Roku 4 Motherboard Replacement: 6 단계, 이미지 1/1
    • After you have created a gap large enough to fit your fingers between, gently lift up the top cover to open the device and reveal the motherboard.
    • The motherboard should still be attached to the underside of the top cover by a red wire, a blue wire, and a black wire.
  7. Roku 4 Motherboard Replacement: 7 단계, 이미지 1/3 Roku 4 Motherboard Replacement: 7 단계, 이미지 2/3 Roku 4 Motherboard Replacement: 7 단계, 이미지 3/3
    • To begin removing the motherboard from the plastic casing, pinch the black plastic clip and gently pull upward.
    • Once you feel the motherboard begin to loosen from the plastic casing, pull it upward to remove it completely.
  8. Roku 4 Motherboard Replacement: 8 단계, 이미지 1/3 Roku 4 Motherboard Replacement: 8 단계, 이미지 2/3 Roku 4 Motherboard Replacement: 8 단계, 이미지 3/3
    • Peel back the black adhesive strip that attaches the blue wire to the motherboard.
    • Repeat this step for the strip that attaches the black and red wires to the motherboard.
  9. Roku 4 Motherboard Replacement: 9 단계, 이미지 1/3 Roku 4 Motherboard Replacement: 9 단계, 이미지 2/3 Roku 4 Motherboard Replacement: 9 단계, 이미지 3/3
    • Using a soldering iron, desolder the blue, red, and black wires from the motherboard.
    • Consult iFixit's Soldering Skills guide to safely use the soldering iron.
    • The motherboard should now be completely disconnected from the top cover of the device.
    So where do I get the new mother board?
    cfasche - 답글
    Later versions of the Roku 4 have a connector for the fan so you do not need a soldering iron.
    Ian West - 답글
결론
Follow these steps in the reverse order to reassemble your device.
다른 7명이 해당 안내서를 완성하였습니다.
Bradley Rains
회원 가입일: 03/26/17
157 평판
안내서 1개 작성함
Baylor, Team S5-G4, Williams Spring 2017 Baylor, Team S5-G4, Williams Spring 2017 회원
BU-WILLIAMS-S17S5G4
3 회원들
안내서 4개 작성하였습니다
댓글 4개
Thank you, have you upgraded to a new 2019 Ultra model yet?
Allan Landwer - 답글
Soldering the fan to the mobo is a suck move. However, they used a good quality bearing-less fan.
smbrannon - 답글
Can you gve me areson? will it suck out the perfomance?
Kind-hearted, spirited Man -
Because it makes replacing the motherboard more difficult. For a few cents more, they could have placed a small connector inline between the fan and motherboard, making disconnecting the fan and top case really easy.
Bob Reed - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 22
전체 시간: 5,404
