주요 콘텐츠로 건너뛰기
Roku 4 Remote Control Motherboard Replacement
필요한 것
  1. Roku 4 Remote Control Motherboard Replacement, Remote Control Motherboard: 1 단계, 이미지 1/1
    • Place the remote control facing down on the table, so that the buttons are facing downwards.
  2. Roku 4 Remote Control Motherboard Replacement: 2 단계, 이미지 1/2 Roku 4 Remote Control Motherboard Replacement: 2 단계, 이미지 2/2
    • Remove the battery compartment cover from the back of the remote by sliding it outwards. This should reveal the batteries.
  3. Roku 4 Remote Control Motherboard Replacement: 3 단계, 이미지 1/2 Roku 4 Remote Control Motherboard Replacement: 3 단계, 이미지 2/2
    • Remove the batteries from the battery compartment.
  4. Roku 4 Remote Control Motherboard Replacement: 4 단계, 이미지 1/1
    • Turn the Phillips PH0 screwdriver counterclockwise to carefully remove the 6.9 mm screw located between both battery compartments .
  5. Roku 4 Remote Control Motherboard Replacement: 5 단계, 이미지 1/1
    • Wedge a plastic opening tool into the seam between the top cover and bottom casing of the device to create a gap.
    • Prying open the remote is quite difficult and requires a large amount of force. Use caution to avoid breaking the device or hurting yourself.
    • Once you have created a gap large enough for your fingers to fit between, separate the top cover from the bottom plastic casing by pulling them apart gently.
  6. Roku 4 Remote Control Motherboard Replacement: 6 단계, 이미지 1/3 Roku 4 Remote Control Motherboard Replacement: 6 단계, 이미지 2/3 Roku 4 Remote Control Motherboard Replacement: 6 단계, 이미지 3/3
    • Using your right thumb, lift up on the left side of the motherboard to remove it from the bottom plastic casing.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Hank Harrison
회원 가입일: 03/26/17
449 평판
안내서 3개 작성하였습니다
Baylor, Team S5-G4, Williams Spring 2017 Baylor, Team S5-G4, Williams Spring 2017 회원
BU-WILLIAMS-S17S5G4
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 19
전체 시간: 1,625
