주요 콘텐츠로 건너뛰기
Roku N1000 Motherboard Replacement
필요한 것
  1. Roku N1000 Motherboard Replacement, Remove Bottom Screws: 1 단계, 이미지 1/2 Roku N1000 Motherboard Replacement, Remove Bottom Screws: 1 단계, 이미지 2/2
    • Remove the Philips head screws on the bottom side if the Roku box.
  2. Roku N1000 Motherboard Replacement, Bottom Half of Case: 2 단계, 이미지 1/1
    • Starting from the back of the box, begin to remove the the bottom of the Roku box using the prying tool.
    • Inside the Roku box on the bottom portion of the case, there are two tabs on both the left and right side.
    • Carefully pop the tabs out and lift the side with the prying tool.
  3. Roku N1000 Motherboard Replacement, Removing the Motherboard: 3 단계, 이미지 1/2 Roku N1000 Motherboard Replacement, Removing the Motherboard: 3 단계, 이미지 2/2
    • Remove the two Philips screws on the motherboard and the screw on the back panel of the Roku box.
    • Carefully lift the Motherboard out of the Roku box.
결론
Ryan Foley
회원 가입일: 10/19/14
101 평판
안내서 1개 작성함
Montana Tech, Team 1-5, Shirk Fall 2014 Montana Tech, Team 1-5, Shirk Fall 2014 회원
MTUM-SHIRK-F14S1G5
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 5
전체 시간: 763
