주요 콘텐츠로 건너뛰기
Roku Streaming Stick Macro Button Contacts Replacement
필요한 것
  1. Roku Streaming Stick Macro Button Contacts Replacement, Macro Button Contacts: 1 단계, 이미지 1개 중 1개
    • Place the remote so that the battery cover is facing upwards.
  2. Roku Streaming Stick Macro Button Contacts Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the battery cover to expose the battery compartment.
  3. Roku Streaming Stick Macro Button Contacts Replacement: 3 단계, 이미지 1개 중 1개
    • Remove batteries.
  4. Roku Streaming Stick Macro Button Contacts Replacement: 4 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the 1.5 mm wide screw.
  5. Roku Streaming Stick Macro Button Contacts Replacement: 5 단계, 이미지 2개 중 1개 Roku Streaming Stick Macro Button Contacts Replacement: 5 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to gently pry apart the plastic enclosure. Make sure you create a large enough gap before you attempt to separate the two pieces.
  6. Roku Streaming Stick Macro Button Contacts Replacement: 6 단계, 이미지 1개 중 1개
    • Gently remove the circuit board or motherboard.
  7. Roku Streaming Stick Macro Button Contacts Replacement: 7 단계, 이미지 1개 중 1개
    • First, gently remove the three plastic sheets. Then, remove the button panels from the remote control.
    • Repair the contact sheet as noted on the Button Contact Repair Kit listed above. Otherwise replace with new conductive button contacts.
결론
작성자
3다른 기여자 명과 함께
Feliciano Bandazi
회원 가입일: 04/07/18
145 평판
안내서 1개를 작성함
IUPUI, Team S2-G2, Wilson Spring 2018 IUPUI, Team S2-G2, Wilson Spring 2018 회원
IUPUI-WILSON-S18S2G2
4 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 29
전체 시간: 3,782
