주요 콘텐츠로 건너뛰기
Roku XD 2050X Remote Motherboard Replacement
필요한 것
  1. Roku XD 2050X Remote Motherboard Replacement, Remote Control Casing: 1 단계, 이미지 1/2 Roku XD 2050X Remote Motherboard Replacement, Remote Control Casing: 1 단계, 이미지 2/2
    • Take care when handling components. Circuit boards, soldering points, and other areas may have sharp points.
    • Remove the battery cover.
    • Remove the two AA batteries.
  2. Roku XD 2050X Remote Motherboard Replacement: 2 단계, 이미지 1/2 Roku XD 2050X Remote Motherboard Replacement: 2 단계, 이미지 2/2
    • Insert flat edge of spudger into seam between the top and bottom halves of the remote control.
    • Gently twist the spudger to separate the top and bottom halves of the remote.
  3. Roku XD 2050X Remote Motherboard Replacement: 3 단계, 이미지 1/1
    • Gently use the spudger to pry the circuit board loose.
  4. Roku XD 2050X Remote Motherboard Replacement: 4 단계, 이미지 1/1
    • Using either end of the spudger, gently lift and remove the clear keypad backing.
  5. Roku XD 2050X Remote Motherboard Replacement: 5 단계, 이미지 1/1
    • Using either end of the spudger, lift and remove the rubber keypad.
  6. Roku XD 2050X Remote Motherboard Replacement, Remote Motherboard: 6 단계, 이미지 1/1
    • Now that the remote is disassembled, you simply need to reassemble the remote using the replacement circuit board.
    • Be sure to dispose of the faulty circuit board properly. Recycle if possible!
결론
To reassemble the remote once you've replaced the circuit board, return to the remote control disassembly page and follow the steps in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
William
회원 가입일: 01/30/15
1,603 평판
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 13
전체 시간: 1,048
