소개
This guide will show you how to repalce the LCD in your Roland TR-505.
Simply firmly hold the cap and carefully pull up and the cap should pop up.
Bonus Step!
While the cap is off it can be worth cleaning under the cap to prevent dirt from getting inside.
This whole guide applies for both dials as they both come off the same way.
Carefully separate the 2 half’s
If it’s not coming apart you may need a plastic pry tool to assist you
Once separated:with the ports facing you open the device like a book with the top panel lifted up slightly,make sure to open it to the right
Carefully unplug the connectors from their sockets by pulling on the tabs that stick out from the cable
with the connectors disconnected you can lift the top half away.
to take the LCD out, take out these PH 1 Philips screws
다른 한 분이 해당 안내서를 완성하였습니다.
