소개
This guide will show you how to replace the switch board in your Roland TR-505
With the dials in front of you carefully pull them up and away from the hide and shaft
Carefully separate the 2 half’s
If it’s not coming apart you may need a plastic pry tool to assist you
Once separated:with the ports facing you open the device like a book with the top panel lifted up slightly,make sure to open it to the right
Carefully unplug the connectors from their sockets by pulling on the tabs that stick out from the cable
with the connectors disconnected you can lift the top half away.
to take the switchboard off take out these PH 1 Philips screws
Thumbs up to Roland for adding arrows to where the screws are on the switch-board:-)
다른 한 분이 해당 안내서를 완성하였습니다.
