주요 콘텐츠로 건너뛰기
Roller Blade Washer Replacement
필요한 것
  1. Roller Blade Washer Replacement, Washer: 1 단계, 이미지 1개 중 1개
    • The roller blade needs to be side down on a flat surface
  2. Roller Blade Washer Replacement: 2 단계, 이미지 1개 중 1개
    • Use an Allen Wrench to unscrew the screws on each side of the wheel.
  3. Roller Blade Washer Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the screws and wheel from the blade.
  4. Roller Blade Washer Replacement: 4 단계, 이미지 1개 중 1개
    • Take the old plastic washer off the long screw.
  5. Roller Blade Washer Replacement: 5 단계, 이미지 1개 중 1개
    • Retrieve the new plastic washer and insert between the blades on the inner side. Do the same to the other side, so that both sides have new plastic washers
  6. Roller Blade Washer Replacement: 6 단계, 이미지 1개 중 1개
    • Replace the wheel without dislodging the new plastic washers and center the hole of the wheel in each plastic washer.
  7. Roller Blade Washer Replacement: 7 단계, 이미지 1개 중 1개
    • Reinsert the screws through the plastic washers and wheel.
  8. Roller Blade Washer Replacement: 8 단계, 이미지 1개 중 1개
    • Lastly, tighten the screws with the Allen Wrench.
결론
You just finished replacing the plastic washers, you can now go out and skate to your hearts content
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Humza Khan
회원 가입일: 02/10/16
125 평판
안내서 1개를 작성함
Colorado Springs, Team 5-5, Mcmichael Spring 2016 Colorado Springs, Team 5-5, Mcmichael Spring 2016 회원
UCCS-MCMICHAEL-S16S5G5
3 회원들
안내서 2개를 작성함
3가이드 댓글
ভিঢা বাজার অগ্রণী ব্যাংকের
হাসিবুর রহমান - 답글
হাসিবুর রহমান - 답글
হাসিবুর রহমান - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 11
전체 시간: 2,671
