주요 콘텐츠로 건너뛰기
Roller Derby Skate Toe Stop Replacement
필요한 것
  1. Roller Derby Skate Toe Stop Replacement, Toe Stop: 1 단계, 이미지 1/2 Roller Derby Skate Toe Stop Replacement, Toe Stop: 1 단계, 이미지 2/2
    • Place the roller skate so the heel is touching the table and the toe is pointing up.
  2. Roller Derby Skate Toe Stop Replacement: 2 단계, 이미지 1/2 Roller Derby Skate Toe Stop Replacement: 2 단계, 이미지 2/2
    • Loosen the nut with the wrench.
  3. Roller Derby Skate Toe Stop Replacement: 3 단계, 이미지 1/3 Roller Derby Skate Toe Stop Replacement: 3 단계, 이미지 2/3 Roller Derby Skate Toe Stop Replacement: 3 단계, 이미지 3/3
    • Twist the toe stop off with your hand.
  4. Roller Derby Skate Toe Stop Replacement: 4 단계, 이미지 1/3 Roller Derby Skate Toe Stop Replacement: 4 단계, 이미지 2/3 Roller Derby Skate Toe Stop Replacement: 4 단계, 이미지 3/3
    • Twist and remove the washer, split lock washer, and nut with your hand.
  5. Roller Derby Skate Toe Stop Replacement: 5 단계, 이미지 1/3 Roller Derby Skate Toe Stop Replacement: 5 단계, 이미지 2/3 Roller Derby Skate Toe Stop Replacement: 5 단계, 이미지 3/3
    • Place the nut, split lock washer, and washer on your new toe stop.
  6. Roller Derby Skate Toe Stop Replacement: 6 단계, 이미지 1/1
    • Align the thread of the toe stop screw with the thread on the skate.
    • The threads on the bolt are a soft metal and can bend, chip or break if you force the thread when screwing the toe stop back on.
  7. Roller Derby Skate Toe Stop Replacement: 7 단계, 이미지 1/1
    • Twist the toe stop back on with your hand.
  8. Roller Derby Skate Toe Stop Replacement: 8 단계, 이미지 1/3 Roller Derby Skate Toe Stop Replacement: 8 단계, 이미지 2/3 Roller Derby Skate Toe Stop Replacement: 8 단계, 이미지 3/3
    • Tighten the nut with the wrench to secure the toe stop in place.
    • Do not over tighten the nut as this can damage the threads on the toe stop or the skate.
    • You will know it's tight enough when you can no longer twist the toe stop off with your hand.
결론
Repeat these steps for each roller skate you wish to replace the toe stop on.
Fabrizio Lopez
회원 가입일: 09/29/21
157 평판
안내서 1개 작성함
University of North Texas, Team 1-9, Raign Fall 2021 University of North Texas, Team 1-9, Raign Fall 2021 회원
UNT-RAIGN-F21S1G9
2 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 16
전체 시간: 1,060
