주요 콘텐츠로 건너뛰기
Roller Skate Double Action Cushion Replacement
필요한 것
  1. Roller Skate Double Action Cushion Replacement, Sure-Grip Double Action Cushion: 1 단계, 이미지 1/1
    • Using a 14 mm wrench, loosen and extract the bolt from the base plate.
  2. Roller Skate Double Action Cushion Replacement: 2 단계, 이미지 1/1
    • Once the bolt is no longer in the base plate, lift and twist the entire truck assembly from the skate.
  3. Roller Skate Double Action Cushion Replacement: 3 단계, 이미지 1/2 Roller Skate Double Action Cushion Replacement: 3 단계, 이미지 2/2
    • Flip the truck over and remove the nut from the truck assembly bolt.
  4. Roller Skate Double Action Cushion Replacement: 4 단계, 이미지 1/2 Roller Skate Double Action Cushion Replacement: 4 단계, 이미지 2/2
    • Remove both sets of cushions and retaining washers from the bolt.
  5. Roller Skate Double Action Cushion Replacement: 5 단계, 이미지 1/3 Roller Skate Double Action Cushion Replacement: 5 단계, 이미지 2/3 Roller Skate Double Action Cushion Replacement: 5 단계, 이미지 3/3
    • Remove the retaining washer from each cushion.
    • Use a spudger if the washer and cushion are difficult to separate.
    • Replace worn cushions and washers.
결론
Jen Rushing
회원 가입일: 05/24/15
1 평판
안내서 1개 작성함
CCNTH Repair Project CCNTH Repair Project 회원
Community
2 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 5
30일 전: 13
전체 시간: 2,132
