주요 콘텐츠로 건너뛰기
Rosewill NEON M62 Bottom Panel Replacement
필요한 것
  1. Rosewill NEON M62 Bottom Panel Replacement, Bottom Panel: 1 단계, 이미지 1/1
    • Place the mouse so the bottom is facing upwards.
    • Remove the plastic skates.
    • These are not shown in the picture since they were missing from the device.
    • Remove the two 5 mm screws with a Phillips #00 screwdriver.
  2. Rosewill NEON M62 Bottom Panel Replacement: 2 단계, 이미지 1/1
    • Use the opening tool along the side of the mouse to open up it.
    • This may take multiple attempts to do so; be patient and careful not to break the mouse.
  3. Rosewill NEON M62 Bottom Panel Replacement: 3 단계, 이미지 1/2 Rosewill NEON M62 Bottom Panel Replacement: 3 단계, 이미지 2/2
    • Loosen the top and bottom half of the mouse with the opening tool, and slowly pull up the bottom half of the mouse.
결론
Joshua Alves
회원 가입일: 03/16/23
97 평판
안내서 1개 작성함
UMass Dartmouth, Team 7-2, Ryckebusch Spring 2023 UMass Dartmouth, Team 7-2, Ryckebusch Spring 2023 회원
UMASSD-RYCKEBUSCH-S23S7G2
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 18
전체 시간: 120
