주요 콘텐츠로 건너뛰기
Rosewill NEON M62 Scroll Wheel RGB Board Replacement
필요한 것
  1. Rosewill NEON M62 Scroll Wheel RGB Board Replacement, Bottom Panel: 1 단계, 이미지 1/1
    • Place the mouse so the bottom is facing upwards.
    • Remove the plastic skates.
    • These are not shown in the picture since they were missing from the device.
    • Remove the two 5 mm screws with a Phillips #00 screwdriver.
  2. Rosewill NEON M62 Scroll Wheel RGB Board Replacement: 2 단계, 이미지 1/1
    • Use the opening tool along the side of the mouse to open up it.
    • This may take multiple attempts to do so; be patient and careful not to break the mouse.
  3. Rosewill NEON M62 Scroll Wheel RGB Board Replacement: 3 단계, 이미지 1/2 Rosewill NEON M62 Scroll Wheel RGB Board Replacement: 3 단계, 이미지 2/2
    • Loosen the top and bottom half of the mouse with the opening tool, and slowly pull up the bottom half of the mouse.
  4. Rosewill NEON M62 Scroll Wheel RGB Board Replacement, Scroll Wheel RGB Board: 4 단계, 이미지 1/2 Rosewill NEON M62 Scroll Wheel RGB Board Replacement, Scroll Wheel RGB Board: 4 단계, 이미지 2/2
    • Use the opening tool to push the scroll wheel RGB board up and to the right until it disconnects.
결론
Julian Abraham
회원 가입일: 03/21/23
414 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 7-2, Ryckebusch Spring 2023 UMass Dartmouth, Team 7-2, Ryckebusch Spring 2023 회원
UMASSD-RYCKEBUSCH-S23S7G2
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 11
전체 시간: 74
