주요 콘텐츠로 건너뛰기
Rosewill NEON M62 Side Buttons Replacement
필요한 것
  1. Rosewill NEON M62 Side Buttons Replacement, Bottom Panel: 1 단계, 이미지 1/1
    • Place the mouse so the bottom is facing upwards.
    • Remove the plastic skates.
    • These are not shown in the picture since they were missing from the device.
    • Remove the two 5 mm screws with a Phillips #00 screwdriver.
  2. Rosewill NEON M62 Side Buttons Replacement: 2 단계, 이미지 1/1
    • Use the opening tool along the side of the mouse to open up it.
    • This may take multiple attempts to do so; be patient and careful not to break the mouse.
  3. Rosewill NEON M62 Side Buttons Replacement: 3 단계, 이미지 1/2 Rosewill NEON M62 Side Buttons Replacement: 3 단계, 이미지 2/2
    • Loosen the top and bottom half of the mouse with the opening tool, and slowly pull up the bottom half of the mouse.
  4. Rosewill NEON M62 Side Buttons Replacement, Top Cover: 4 단계, 이미지 1/2 Rosewill NEON M62 Side Buttons Replacement, Top Cover: 4 단계, 이미지 2/2
    • Hold the top half of the mouse with your non-dominant hand.
    • With your dominant hand, push an opening tool into the gaps in the panel.
    • Pry the panel off.
  5. Rosewill NEON M62 Side Buttons Replacement, Side Buttons: 5 단계, 이미지 1/1
    • Using the opening tool, take the mouse 1 and mouse 2 buttons off the top of the mouse.
  6. Rosewill NEON M62 Side Buttons Replacement: 6 단계, 이미지 1/1
    • Remove the mouse 1 and mouse 2 buttons.
  7. Rosewill NEON M62 Side Buttons Replacement: 7 단계, 이미지 1/1
    • Place the mouse on its back.
  8. Rosewill NEON M62 Side Buttons Replacement: 8 단계, 이미지 1/1
    • Move around the mouse piece with an opening tool, and loosen up the piece.
  9. Rosewill NEON M62 Side Buttons Replacement: 9 단계, 이미지 1/1
    • Grab the mouse piece and take it out.
  10. Rosewill NEON M62 Side Buttons Replacement: 10 단계, 이미지 1/1
    • You're now ready to replace the side buttons.
결론
Sean Turk
회원 가입일: 03/16/23
217 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 7-2, Ryckebusch Spring 2023 UMass Dartmouth, Team 7-2, Ryckebusch Spring 2023 회원
UMASSD-RYCKEBUSCH-S23S7G2
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 3
전체 시간: 64
