주요 콘텐츠로 건너뛰기
RotoZip Rebel REB01 Type 2 Motor Replacement
필요한 것
  1. RotoZip Rebel REB01 Type 2 Motor Replacement, Saw Casing: 1 단계, 이미지 1/1
    • Unplug the saw before attempting any of the replacement guides.
    • Orient the saw so that the handle is closest to you and the saw end points towards the left.
  2. RotoZip Rebel REB01 Type 2 Motor Replacement: 2 단계, 이미지 1/2 RotoZip Rebel REB01 Type 2 Motor Replacement: 2 단계, 이미지 2/2
    • Push down on the grey lock on the right side of the handle to unlock it.
    • Pull the handle to detach it from the saw.
  3. RotoZip Rebel REB01 Type 2 Motor Replacement: 3 단계, 이미지 1/2 RotoZip Rebel REB01 Type 2 Motor Replacement: 3 단계, 이미지 2/2
    • Lift the black lock at the tip of the saw to unlock the depth gauge.
    • Pull the depth gauge to detach it from the saw.
  4. RotoZip Rebel REB01 Type 2 Motor Replacement: 4 단계, 이미지 1/1
    • Rotate the device so that the bottom of the saw is facing upwards.
    • Remove the six 20mm screws with a 6mm flathead screwdriver.
  5. RotoZip Rebel REB01 Type 2 Motor Replacement: 5 단계, 이미지 1/2 RotoZip Rebel REB01 Type 2 Motor Replacement: 5 단계, 이미지 2/2
    • Cut through the stickers on the right and left sides of the saw using a metal spudger.
    • Pull off the top half of the casing.
  6. RotoZip Rebel REB01 Type 2 Motor Replacement, Motor: 6 단계, 이미지 1/1
    • Lift the motor assembly out of the casing.
    • The white plastic piece connecting the wires and holding the motor brushes in place is fragile. Be careful to not break it when removing the motor assembly.
  7. RotoZip Rebel REB01 Type 2 Motor Replacement: 7 단계, 이미지 1/2 RotoZip Rebel REB01 Type 2 Motor Replacement: 7 단계, 이미지 2/2
    • Detach the wire connected to the bottom of the motor assembly.
    • Rotate the motor away from you so that the second wire is visible, and detach that wire as well.
결론
Lauren Russell
회원 가입일: 10/05/16
224 평판
안내서 3개 작성하였습니다
Cal Poly, Team 4-4, Livingston Fall 2016 Cal Poly, Team 4-4, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S4G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 5
30일 전: 15
전체 시간: 2,349
