주요 콘텐츠로 건너뛰기
RotoZip Rebel REB01 Type 2 Power Cord Replacement
필요한 것
  1. RotoZip Rebel REB01 Type 2 Power Cord Replacement, Saw Casing: 1 단계, 이미지 1/1
    • Unplug the saw before attempting any of the replacement guides.
    • Orient the saw so that the handle is closest to you and the saw end points towards the left.
  2. RotoZip Rebel REB01 Type 2 Power Cord Replacement: 2 단계, 이미지 1/2 RotoZip Rebel REB01 Type 2 Power Cord Replacement: 2 단계, 이미지 2/2
    • Push down on the grey lock on the right side of the handle to unlock it.
    • Pull the handle to detach it from the saw.
  3. RotoZip Rebel REB01 Type 2 Power Cord Replacement: 3 단계, 이미지 1/2 RotoZip Rebel REB01 Type 2 Power Cord Replacement: 3 단계, 이미지 2/2
    • Lift the black lock at the tip of the saw to unlock the depth gauge.
    • Pull the depth gauge to detach it from the saw.
  4. RotoZip Rebel REB01 Type 2 Power Cord Replacement: 4 단계, 이미지 1/1
    • Rotate the device so that the bottom of the saw is facing upwards.
    • Remove the six 20mm screws with a 6mm flathead screwdriver.
  5. RotoZip Rebel REB01 Type 2 Power Cord Replacement: 5 단계, 이미지 1/2 RotoZip Rebel REB01 Type 2 Power Cord Replacement: 5 단계, 이미지 2/2
    • Cut through the stickers on the right and left sides of the saw using a metal spudger.
    • Pull off the top half of the casing.
  6. RotoZip Rebel REB01 Type 2 Power Cord Replacement, Power Cord: 6 단계, 이미지 1/2 RotoZip Rebel REB01 Type 2 Power Cord Replacement, Power Cord: 6 단계, 이미지 2/2
    • Remove the two 14 mm screws on the plastic plate holding the power cord with a flat head screwdriver.
    • Lift off the plastic plate holding the power cord with a tweezer.
  7. RotoZip Rebel REB01 Type 2 Power Cord Replacement: 7 단계, 이미지 1/1
    • Pull the switchboard out slowly.
    • The power switch will also come out. Set it on the side.
  8. RotoZip Rebel REB01 Type 2 Power Cord Replacement: 8 단계, 이미지 1/2 RotoZip Rebel REB01 Type 2 Power Cord Replacement: 8 단계, 이미지 2/2
    • Pinch the two white clips with your thumb while simultaneously removing the black and white wires.
    • Remove the power cord from the saw.
    • When reassembling, make sure to plug the black wire into the top clip.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Ezzeddeen Gazali
회원 가입일: 10/06/16
81 평판
안내서 1개 작성함
Cal Poly, Team 4-4, Livingston Fall 2016 Cal Poly, Team 4-4, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S4G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 5
30일 전: 12
전체 시간: 604
