소개
Damaged power cord? Why throw your saw away when you can fix it. If your saw has a damaged power cord, this guide will provide you with step-by-step instructions for the power cord replacement.
필요한 것
Orient the saw so that the handle is closest to you and the saw end points towards the left.
Remove the two 14 mm screws on the plastic plate holding the power cord with a flat head screwdriver.
Lift off the plastic plate holding the power cord with a tweezer.
다른 2명이 해당 안내서를 완성하였습니다.
