소개
If the power switch is stuck or not functioning anymore, you will need to replace the power switch circuit board. in order to replace the power switch circuit board you will need to remove the saw casing and motor assembly.
필요한 것
Orient the saw so that the handle is closest to you and the saw end points towards the left.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
Nice guide, I can’t seem to find the switch online, it seems to be discontinued
