주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Rotor Riot Face Button Replacement
필요한 것
  1. Rotor Riot Face Button Replacement, Remove the iPhone mount: 1 단계, 이미지 3개 중 1개 Rotor Riot Face Button Replacement, Remove the iPhone mount: 1 단계, 이미지 3개 중 2개 Rotor Riot Face Button Replacement, Remove the iPhone mount: 1 단계, 이미지 3개 중 3개
    • Use your fingers to remove the screw on the back side of the controller securing the iPhone mount.
    • Remove the iPhone mount.
  2. Rotor Riot Face Button Replacement, Unscrew the back cover: 2 단계, 이미지 1개 중 1개
    • Use a T6 Torx screwdriver to remove the eight 9.2 mm-long screws securing the back cover.
    • Don't try to remove the back cover all the way yet! It's still connected to the mainboard.
  3. Rotor Riot Face Button Replacement, Swing open the back cover: 3 단계, 이미지 3개 중 1개 Rotor Riot Face Button Replacement, Swing open the back cover: 3 단계, 이미지 3개 중 2개 Rotor Riot Face Button Replacement, Swing open the back cover: 3 단계, 이미지 3개 중 3개
    • Lift up the back cover of the controller.
    • Lift the back cover to a 45 degree angle and place it next to the controller.
    • Don't strain the interconnect cable during this procedure.
  4. Rotor Riot Face Button Replacement, Disconnect the phone connector cable: 4 단계, 이미지 3개 중 1개 Rotor Riot Face Button Replacement, Disconnect the phone connector cable: 4 단계, 이미지 3개 중 2개 Rotor Riot Face Button Replacement, Disconnect the phone connector cable: 4 단계, 이미지 3개 중 3개
    • Use a spudger to disconnect the phone connector cable from the mainboard.
  5. Rotor Riot Face Button Replacement, Remove the back cover: 5 단계, 이미지 1개 중 1개
    • Remove the back cover.
  6. Rotor Riot Face Button Replacement, Remove the shoulder buttons: 6 단계, 이미지 2개 중 1개 Rotor Riot Face Button Replacement, Remove the shoulder buttons: 6 단계, 이미지 2개 중 2개
    • Remove the shoulder buttons by lifting them out of the case.
  7. Rotor Riot Face Button Replacement, Unscrew the mainboard: 7 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the four 7.0 mm-long screws securing the mainboard.
  8. Rotor Riot Face Button Replacement, Flip over the mainboard: 8 단계, 이미지 3개 중 1개 Rotor Riot Face Button Replacement, Flip over the mainboard: 8 단계, 이미지 3개 중 2개 Rotor Riot Face Button Replacement, Flip over the mainboard: 8 단계, 이미지 3개 중 3개
    • Flip over the mainboard and place it above the controller housing.
    • Avoid tensioning the trigger button cables during this procedure and don't try to remove the mainboard all the way yet! It is still connected to the controller housing.
  9. Rotor Riot Face Button Replacement, Remove the face buttons: 9 단계, 이미지 2개 중 1개 Rotor Riot Face Button Replacement, Remove the face buttons: 9 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to remove the face buttons from the housing.
    • The alignment pegs on each button are designed to prevent incorrect installation. Make sure your new buttons fit properly in the controller case.
결론
작성자
2다른 기여자 명과 함께
Adriana Zwink
회원 가입일: 12/18/19
66,732 평판
안내서 167개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 25,685개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 50
전체 시간: 340
