주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Rowenta AC6221 수리는 저희 서비스 설명서를 사용하십시오.
  1. Rowenta AC6221 Teardown, Rowenta AC6221 Teardown: 1 단계, 이미지 1/3 Rowenta AC6221 Teardown, Rowenta AC6221 Teardown: 1 단계, 이미지 2/3 Rowenta AC6221 Teardown, Rowenta AC6221 Teardown: 1 단계, 이미지 3/3
    • The 4.8 Rowenta vacuum can be used for a variety of purposes.
    • It is charged through its pedestal. The power of the pedestal is:
    • Input: 230V - 50 Hz - 7W (AC)
    • Output: 7.5V - 300 mA (DC)
  2. Rowenta AC6221 Teardown: 2 단계, 이미지 1/3 Rowenta AC6221 Teardown: 2 단계, 이미지 2/3 Rowenta AC6221 Teardown: 2 단계, 이미지 3/3
    • This vacuum has several parts:
    • The tip
    • The reservoir which holds the dust and debris
    • The engine (4.8V)
    • The pedestal
    • The power supply
    • From top to bottom, the reservoir contains 3 parts: the housing, container, and filter.
  3. Rowenta AC6221 Teardown: 3 단계, 이미지 1/3 Rowenta AC6221 Teardown: 3 단계, 이미지 2/3 Rowenta AC6221 Teardown: 3 단계, 이미지 3/3
    • Remove the two outer Philips #00 screws from the bottom of the engine.
    • The back of the circuit board will now be visible.
  4. Rowenta AC6221 Teardown: 4 단계, 이미지 1/3 Rowenta AC6221 Teardown: 4 단계, 이미지 2/3 Rowenta AC6221 Teardown: 4 단계, 이미지 3/3
    • Remove the two inner screws.
    • Insert a flat screwdriver between the cover and the base of the engine and remove the cover.
    • The wires of the vacuum are now visible.
  5. Rowenta AC6221 Teardown: 6 단계, 이미지 1/2 Rowenta AC6221 Teardown: 6 단계, 이미지 2/2
    • The wires connect the charger light, switch,engine, and power wires.
    • The green box labels the engine.
    • The orange box labels one of the four batteries (4*1.2V)
  6. Rowenta AC6221 Teardown: 7 단계, 이미지 1/2 Rowenta AC6221 Teardown: 7 단계, 이미지 2/2
    • The top of the circuit board contains components including capacitors, resistors, wires, and a chip.
    • The bottom side shows the tracks that connect the components.
  7. Rowenta AC6221 Teardown: 8 단계, 이미지 1/2 Rowenta AC6221 Teardown: 8 단계, 이미지 2/2
    • Remove the screw securing the handle with a screwdriver.
    • Open the handle to see the inside using the flat screwdriver.
    • Warning: The handle is difficult to open
    • Warning: In this procedure, the handle was not opened to keep the vacuum intact.
  8. Rowenta AC6221 Teardown: 9 단계, 이미지 1/1
    • This is the pedestal that will be torn down.
  9. Rowenta AC6221 Teardown: 10 단계, 이미지 1/3 Rowenta AC6221 Teardown: 10 단계, 이미지 2/3 Rowenta AC6221 Teardown: 10 단계, 이미지 3/3
    • At the bottom of the pedestal, remove the 4 rubber pieces.
    • Note: This step provides access to 4 Philips screws.
    • Remove screws using a screwdriver.
  10. Rowenta AC6221 Teardown: 11 단계, 이미지 1/1
    • Lift the plastic piece carefully from the bottom of the pedestal.
  11. Rowenta AC6221 Teardown: 12 단계, 이미지 1/1
    • Inside the pedestal, the power cable separates into 2 wires. Each wire is connected to a conductive piece.
    • This completes the vacum cleaner teardown
Bob
회원 가입일: 04/17/10
760 평판
안내서 3개 작성하였습니다
댓글 한 개
This could use some discussion of how to replace the rechargeable batteries used in portable vacuum cleaners.
Wayne Seltzer - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 17
전체 시간: 7,199
