소개
This guide details how to replace the part that includes the spray and steam buttons on the top of the Rowenta Focus DW5080. If one becomes stuck, or one of them is not releasing water, the button needs to be replaced. This part can also be removed to clean out the spray and steam tubes if they are backed up with mineral deposits. You will need to buy the replacement piece and follow the steps in this guide to replace the steam and spray button piece. The user needs to be careful when removing the piece because it is hard to make it loose the first time it is being removed.
Before beginning this repair, turn off the iron and unplug it from the wall outlet.
필요한 것
Insert the metal spudger into the space between the spray/steam button piece and the rest of the iron.
Using the metal spudger for leverage, pry the piece away from the rest of the iron until it can be lifted out.
Lift out the piece.
다른 한 분이 해당 안내서를 완성하였습니다.
