주요 콘텐츠로 건너뛰기
Royal Enfield:How to Clean Final Drive Chain
  1. Royal Enfield:How to Clean Final Drive Chain, Things Required: 1 단계, 이미지 3개 중 1개 Royal Enfield:How to Clean Final Drive Chain, Things Required: 1 단계, 이미지 3개 중 2개 Royal Enfield:How to Clean Final Drive Chain, Things Required: 1 단계, 이미지 3개 중 3개
    • Things required:
    • 1. A bottle of 500 ml diesel or any low solvent oil, like kerosene 2. A used toothbrush 3. A can 4. Clean cotton cloth. 5 Motul Chain lube C-2 6. Hand wrench no.10
  2. Royal Enfield:How to Clean Final Drive Chain, Cleaning The Chain: 2 단계, 이미지 3개 중 1개 Royal Enfield:How to Clean Final Drive Chain, Cleaning The Chain: 2 단계, 이미지 3개 중 2개 Royal Enfield:How to Clean Final Drive Chain, Cleaning The Chain: 2 단계, 이미지 3개 중 3개
    • 1. Keep the motorcycle in centre stand. 2. Unscrew the two screws of Chain Cover and remove the cover. 3. Pour some quantity of diesel to a clean container. 4. Dip the toothbrush in diesel. 5. Start brushing the rollers and both sides of the chain thoroughly while rotating the rear tyre slowly. 6. Once done wipe the chain with the cotton cloth.
  3. Royal Enfield:How to Clean Final Drive Chain, Lubing the Chain: 3 단계, 이미지 2개 중 1개 Royal Enfield:How to Clean Final Drive Chain, Lubing the Chain: 3 단계, 이미지 2개 중 2개
    • 7. Now spray the Motul Chain lube C-2 from a close distance while rotating the rear tyre slowly. 8. Wait for 10 minutes. 9. Put the Chain Cover in appropriate position and tight the screws.
결론
다른 15명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
soumitra sengupta
회원 가입일: 02/04/16
532 평판
안내서 1개를 작성함
2가이드 댓글
Two points, why Diesel SHOUDN'T be used! First: The Diesel will attack the seals between the rings of the chain, wich prevent the lifetime grease filling to come out (same thing with Kerosine, Petroleum, Gasoline and high concentrations of any alcohol). If the Grease filling already came out, the chain is still useable, but it will wear out very fast. Second point is that the Diesel (which is pretty toxic and harmful to animals and humans) goes on the street and the next rain will take it in the nature. So DON'T use it! Don't wanna make advertisement, but I'm using the products from GreenOil, wich are 100% plant based and completely Biodegradable (http://www.green-oil.net). If you don't wanna take this, use something wich is declared as a special motorcycle chain cleaning product and compatible with O-,X-,W-Chains (probably Motul has one of these in their programs).
Leonard Kesting - 답글
Good وممتاز
Hada - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 42
지난 30일: 170
전체 시간: 9,740
