주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Royal Heat RS-100 Fuse Replacement
필요한 것
  1. Royal Heat RS-100 Fuse Replacement, Panel: 1 단계, 이미지 1개 중 1개
    • Unplug the power cord.
    • Flip the device over so the bottom is facing up.
    • Remove the two 10mm screws holding the back panel using a Phillips #2 screwdriver.
  2. Royal Heat RS-100 Fuse Replacement: 2 단계, 이미지 3개 중 1개 Royal Heat RS-100 Fuse Replacement: 2 단계, 이미지 3개 중 2개 Royal Heat RS-100 Fuse Replacement: 2 단계, 이미지 3개 중 3개
    • Place the Flathead Screw driver parallel with the gap between the back and the heater body, then twist until the two parts of panel are separated. You may have to do this on four sides of the panel.
    • Remove the front panel by pulling them apart. The front panel should come out easily.
  3. Royal Heat RS-100 Fuse Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the two dial caps from the two switches by lifting them up.
  4. Royal Heat RS-100 Fuse Replacement, Fuse: 4 단계, 이미지 2개 중 1개 Royal Heat RS-100 Fuse Replacement, Fuse: 4 단계, 이미지 2개 중 2개
    • Do not pry from the middle of the fuse because some fuses are made of glass.
    • Pry one end of the fuse from the bracket until it is separated from the holder.
    • Remove the fuse by lifting it up.
결론
작성자
2다른 기여자 명과 함께
Long Tran
회원 가입일: 10/14/13
205 평판
안내서 2개를 작성함
Cal Poly, Team 11-35, Amido Fall 2013 Cal Poly, Team 11-35, Amido Fall 2013 회원
CPSU-AMIDO-F13S11G35
4 회원들
안내서 13개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 18
전체 시간: 763
