소개
Replace the switch spring inside your Royal Kludge GK64 keyboard key using this guide. Mechanical keyboard switch springs may need to be replaced in a number of circumstances. The key switch springs may eventually appear worn out from constant use or they may cease working completely. Because the process is similar for many mechanical keyboard models, these steps may also be useful for other mechanical keyboard models.
필요한 것
Use a keycap remover to pull your keycap up and off of the keyboard.
다른 한 분이 해당 안내서를 완성하였습니다.
