주요 콘텐츠로 건너뛰기
Royal Kludge GK64 Keyboard Switch Spring Replacement
필요한 것
  1. Royal Kludge GK64 Keyboard Switch Spring Replacement, Keyboard Switch Spring: 1 단계, 이미지 2개 중 1개 Royal Kludge GK64 Keyboard Switch Spring Replacement, Keyboard Switch Spring: 1 단계, 이미지 2개 중 2개
    • Use a keycap remover to pull your keycap up and off of the keyboard.
    • Remove any keycaps surrounding the one you are working on if you need more space.
  2. Royal Kludge GK64 Keyboard Switch Spring Replacement: 2 단계, 이미지 3개 중 1개 Royal Kludge GK64 Keyboard Switch Spring Replacement: 2 단계, 이미지 3개 중 2개 Royal Kludge GK64 Keyboard Switch Spring Replacement: 2 단계, 이미지 3개 중 3개
    • Use the switch puller to pull the desired switch out of your keyboard.
  3. Royal Kludge GK64 Keyboard Switch Spring Replacement: 3 단계, 이미지 2개 중 1개 Royal Kludge GK64 Keyboard Switch Spring Replacement: 3 단계, 이미지 2개 중 2개
    • Place your switch onto your switch opener, and gently push down.
    • Make sure the switch is securely in place and continue to remove the top housing.
  4. Royal Kludge GK64 Keyboard Switch Spring Replacement: 4 단계, 이미지 3개 중 1개 Royal Kludge GK64 Keyboard Switch Spring Replacement: 4 단계, 이미지 3개 중 2개 Royal Kludge GK64 Keyboard Switch Spring Replacement: 4 단계, 이미지 3개 중 3개
    • Use the stem holder to remove the stem, which will reveal the switch spring.
    • Remove the switch spring.
  5. Royal Kludge GK64 Keyboard Switch Spring Replacement: 5 단계, 이미지 2개 중 1개 Royal Kludge GK64 Keyboard Switch Spring Replacement: 5 단계, 이미지 2개 중 2개
    • Align your new spring with the center of the bottom housing and gently place the switch spring.
  6. Royal Kludge GK64 Keyboard Switch Spring Replacement: 6 단계, 이미지 3개 중 1개 Royal Kludge GK64 Keyboard Switch Spring Replacement: 6 단계, 이미지 3개 중 2개 Royal Kludge GK64 Keyboard Switch Spring Replacement: 6 단계, 이미지 3개 중 3개
    • To put the stem back, align the stem legs with the metal plate on the switch.
    • Remove the switch from the switch opener.
    • Gently push down onto the housing until you hear a click and both pieces are into place.
  7. Royal Kludge GK64 Keyboard Switch Spring Replacement: 7 단계, 이미지 2개 중 1개 Royal Kludge GK64 Keyboard Switch Spring Replacement: 7 단계, 이미지 2개 중 2개
    • Align the pins located at the bottom of the switch to the corresponding pin holes in the keyboard.
    • Gently push the switch back into the keyboard.
  8. Royal Kludge GK64 Keyboard Switch Spring Replacement: 8 단계, 이미지 1개 중 1개
    • Place the keycap back onto the switch and push down to secure the keycap.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Diksha Sakre
회원 가입일: 09/19/22
228 평판
안내서 1개를 작성함
York University, Team A-7, Morris Fall 2022 York University, Team A-7, Morris Fall 2022 회원
YORK-MORRIS-F22SAG7
3 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 13
지난 30일: 27
전체 시간: 621
