소개
The Royal Kludge RK-71 keyboard is a mechanical gaming keyboard that was built with hot-swappable switches; this means that when it comes to repairing and changing switches, it is easy for the user to pull out the switch using a switch puller.
As the RK-71 has two product lines, it is important to be sure that your keyboard is hot-swappable before following this guide. The purpose of hot-swappable keyboard is to make it easier to repair and replace the switch, the process of which can be moderately difficult, so I would advise some experience with disassembly and repair of products before attempting this fix. Nonetheless, this guide will take you through the step by step of how to clean the keyboard and replace a switch.
필요한 것
Disconnect the keyboard from any connections by removing the wire.
The RK 71 offers two dual-connection, which means that it is able to connect both with wire and Bluetooth.
Make sure to turn off the back switch to completely disconnect.
Look at the bottom of the switches and locate the two metal pins connectors. These connectors will correspond to the two holes at the position where you will place the switches on the keyboard plates.
Align the switch to the receptacle and gently push the bottom of the switch so that the two pins are in position (do not force it in or else the pins might break),
