주요 콘텐츠로 건너뛰기
Royal Sovereign Fan Replacement
필요한 것
  1. Royal Sovereign Fan Replacement, Fan: 1 단계, 이미지 1/2 Royal Sovereign Fan Replacement, Fan: 1 단계, 이미지 2/2
    • Make sure that the heater is unplugged and completely cooled down.
    • Turn the heater so the back is facing up.
    • Remove all six 14 mm screws using the Philips #0 screwdriver.
  2. Royal Sovereign Fan Replacement: 2 단계, 이미지 1/1
    • Separate the back case from the heater.
  3. Royal Sovereign Fan Replacement: 3 단계, 이미지 1/2 Royal Sovereign Fan Replacement: 3 단계, 이미지 2/2
    • You are left with the motor and wires attached to the front case.
    • Use the Phillips #1 screwdriver to remove the four 14 mm screws attaching the motor to the front case..
    • Do not untangle the wires
  4. Royal Sovereign Fan Replacement: 4 단계, 이미지 1/2 Royal Sovereign Fan Replacement: 4 단계, 이미지 2/2
    • Turn the motor over to reveal the fan.
    • Use a plier to twist and unscrew the hexagonal screw attached to the fan.
  5. Royal Sovereign Fan Replacement: 5 단계, 이미지 1/1
    • Take the fan out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Mohammed Jubair Rabbani
회원 가입일: 05/14/21
145 평판
안내서 1개 작성함
York University, Team S1-G21, O'Regan Summer 2021 York University, Team S1-G21, O'Regan Summer 2021 회원
YORK-O'REGAN-SU21S1G21
1 회원
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 19
전체 시간: 356
