주요 콘텐츠로 건너뛰기
Rozia HQ242 Trimmer Spring Replacement
필요한 것
  1. Rozia HQ242 Trimmer Spring Replacement, Spring: 1 단계, 이미지 3개 중 1개 Rozia HQ242 Trimmer Spring Replacement, Spring: 1 단계, 이미지 3개 중 2개 Rozia HQ242 Trimmer Spring Replacement, Spring: 1 단계, 이미지 3개 중 3개
    • Use a Phillips #1 screwdriver to remove the two 6 mm screws securing the blade to the trimmer.
  2. Rozia HQ242 Trimmer Spring Replacement: 2 단계, 이미지 2개 중 1개 Rozia HQ242 Trimmer Spring Replacement: 2 단계, 이미지 2개 중 2개
    • Gently lift the inner blade straight up and away from the device.
    • With the blades removed, now is a good time to clean the trimmer using a small brush, dust blower, or q-tips.
  3. Rozia HQ242 Trimmer Spring Replacement: 3 단계, 이미지 3개 중 1개 Rozia HQ242 Trimmer Spring Replacement: 3 단계, 이미지 3개 중 2개 Rozia HQ242 Trimmer Spring Replacement: 3 단계, 이미지 3개 중 3개
    • Gently lift the spring away from the trimmer.
    • You may need to point the legs of the spring at a 45-degree angle before you can pull it out.
    • Take note of the shape of the spring. There is a flat U-shaped bend that rests on a notch in the trimmer. This information will be important when putting everything back together!
  4. Rozia HQ242 Trimmer Spring Replacement: 4 단계, 이미지 3개 중 1개 Rozia HQ242 Trimmer Spring Replacement: 4 단계, 이미지 3개 중 2개 Rozia HQ242 Trimmer Spring Replacement: 4 단계, 이미지 3개 중 3개
    • Align the flat U-shaped end of the spring to the notch on the trimmer.
    • Gently pinch the two legs of the spring with your thumb and index finger, aligning them to point towards the front of the trimmer at a 45-degree angle, then drop it into the slot.
    • Once it is successfully in, carefully let go. If it falls off the notch, you will have to wedge it out and try again. This may take multiple attempts.
    • Make sure that the spring is securely resting on the notch, or the trimmer may not function properly!
  5. Rozia HQ242 Trimmer Spring Replacement: 5 단계, 이미지 3개 중 1개 Rozia HQ242 Trimmer Spring Replacement: 5 단계, 이미지 3개 중 2개 Rozia HQ242 Trimmer Spring Replacement: 5 단계, 이미지 3개 중 3개
    • Reinstall the inner blade.
    • The notch located on the back of the blade must align with the gold-plated contact.
    • Gently push down so that the plate rests against the front of the trimmer.
    • Take extra caution not to dislodge the spring from its position, especially after pressing down on the blade.
  6. Rozia HQ242 Trimmer Spring Replacement: 6 단계, 이미지 3개 중 1개 Rozia HQ242 Trimmer Spring Replacement: 6 단계, 이미지 3개 중 2개 Rozia HQ242 Trimmer Spring Replacement: 6 단계, 이미지 3개 중 3개
    • Carefully reattach the outer blade.
    • The screw holes protrude just enough to allow the blade to 'click' into position.
    • Use a Phillips #1 screwdriver to replace the two 6 mm screws that secure the outer blade.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jose Lucio
회원 가입일: 03/05/24
201 평판
안내서 1개를 작성함
CSU Los Angeles, Team 8-3, Grodsky Spring 2024 CSU Los Angeles, Team 8-3, Grodsky Spring 2024 회원
CSULA-GRODSKY-S24S8G3
2 회원들
안내서 2개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 45
전체 시간: 599
