소개
If the Rug Doctor is not spraying properly, you may need to replace the pump .
The Mighty Pro and the X3 models have one pump , while the Wide Track (WT) model has two identical pumps running in parallel. This guide is written with the Wide Track model, but can be used for any of the three models.
Optional tools:
- Straight edge cutters/pincers instead of hose clamp pliers
- Clamp cutter/removal tool
- Hair dryer/heat gun
필요한 것
For single-pump models (Mighty Pro, X3), if the Rug Doctor does not spray at all, the pump requires replacement.
For the Wide Track model, if the Rug Doctor does not spray at all, both pumps require replacement.
If water splashes out of the nozzles for the Wide Track model but does not spray adequately, check the spray nozzles for clogs first.
If the nozzles are clear, one of the two pumps may be defective, not supplying sufficient pressure to the nozzles. If possible, replace both pumps.
If you need to determine which of the two pumps requires replacement, switch the Rug Doctor on to the upholstery mode. Do not disconnect the quick-connect for accessories. If water splashes out of the nozzles like the carpet mode, replace the front pump.
If water does not splash out of the nozzles in accessory mode, replace the rear pump.
Use pliers to grip and wiggle the axle hub cap to loosen it.
Pull the axle cap off.
I had a lot of trouble with this step. I started by grabbing each cap with a pair of pliers and wiggling in opposite directions; they would twist but wouldn’t come off. Then I used a screwdriver to try prying one cap off (be sure to put a putty knife or other thin and stiff piece of metal between your prying tool and the wheel to avoid damage). I managed to move the cap off somewhat, but whenever I pried up one side of the cap, the other would go down. I eventually managed it by crushing the cap using a pair of adjustable pliers.
It was a little difficult but i kept moving it side to side and it finally let go
Remove the crimped hose clamps securing from each end of the pump you are replacing.
You can use a clamp removal tool to cut the clamps.
Alternatively, use pliers to unlatch the small retaining tab on the clamp.
Pry the clamp apart to loosen it.
Use your fingers or pliers to pull the hoses off of the pump nozzles.
Cut the zip ties holding the bundle of wires together.
Carefully trace the two wires coming out of the pump you are replacing.
The pump wires should connect to a black wire and a white wire.
There may be a diode attached in-line on the red wire.
Disconnect the pump by pulling the wire terminals apart. This may take significant force. Pull at the terminals, not the wires.
The wires did not come apart easily for me. I had to cut into some of the plastic shielding and then I used a small, thin flathead to work them apart. Decided to shrink wrap the connectors with new plastic shrink tubes.
Remove the pump.
Remove the orange caps from the nozzles.
Make sure that the pump is installed in the correct direction.
Check that the nozzles are pointed towards the back of the machine.
To reassemble your device, follow these instructions in reverse order while noting the re-assembly tips.
다른 28명이 해당 안내서를 완성하였습니다.
댓글 15개
I would like to view how to open the housing & replace the pump on the Rug Doctor model DC 1.
My X3 model rug doctor continuously sprays Until it runs out of water doesn't matter if the red button is pressed or not when you turn on the machine, it starts sprain. Any thoughts?
Hi Mike,
Does it full-on spray, or just leak? It could be that the red button is broken. Look through this guide. You may be able to disconnect the spray button wires through the black cutout. If the Rug Doctor still sprays with the button disconnected, then the problem is elsewhere.
We replaced our pump but still does spray. We have the doctor deep carpet cleaner model with single pump.
Do you know which way for sure the pump nozzles should be facing on our model? Maybe they’re in wrong though we are hundred percent sure it’s in how old one came out.
Hi Jerri,
I unfortunately don’t. When you press the spray button, does it sound like the pump revs up? If not, it may be a switch problem.
Hello. mightily pro X3. I pushed red button but very little water comes out…. I am assuming I need to replace the pump? please advise. tank is full of water.
Dede
Hi Dede,
I would check the nozzles to make sure they are not clogged first. If possible, take the device apart and check the hoses to make sure they’re not clogged.
Do you have any tips on how to open up, split apart or remove the hard plastic piece on the waste water tank for the Rug Doctor Deep Cleaner? It's the top piece where the tools plug into. There is so much gunk underneath there that you cannot get to it by regular cleaning.
My rug doctor x3 is putting out water really fast and refill every 3 minutes. Single pump I took the pump apart to the clean and flush dog hair and dirt from previous owner. Just gave to me. Would cut it on and nothing and nothing I could see water in hose. But now its all just going fast can't find any things on the pump if I used it right
Some of these comments, I am hoping English is their second language. Some of them, it is obvious English is their primary language, and the review is equally as difficult to understand. Maybe they are bots and the comments are auto generated. I hope it’s that….lol
Anyways… you’re a legend for doing this tear- down. Thank you. One of the best most straightforward tear-downs I’ve ever read… and I fix a lot of stuff. I just wanted to thank you for taking the time to help others. You probably saved me an entire day. I thought the pump was in a different section of the vacuum.
My god is this thing gross on the inside. The repair only took 20mins. I spend another 3 hours removing that brush and soaking it, and chiseling off solid hockey puck sized clumps of hair. The smell is almost unbearable. I debated just tossing it. I will never let someone borrow my rug doctor again. lol.
Seriously tho… thank you. Quality work speaks for itself.
