주요 콘텐츠로 건너뛰기
Rydis H68 Pro Motherboard Replacement
필요한 것
  1. Rydis H68 Pro Motherboard Replacement, Battery: 1 단계, 이미지 1/2 Rydis H68 Pro Motherboard Replacement, Battery: 1 단계, 이미지 2/2
    • Flip the vacuum over so that the wheels are facing you.
    • Use a Phillips #1 screwdriver to remove the four 10 mm screws that surround the battery cover.
  2. Rydis H68 Pro Motherboard Replacement: 2 단계, 이미지 1/1
    • Lift the battery cover up to reveal the battery.
    • Remove the battery.
  3. Rydis H68 Pro Motherboard Replacement, Bumper: 3 단계, 이미지 1/3 Rydis H68 Pro Motherboard Replacement, Bumper: 3 단계, 이미지 2/3 Rydis H68 Pro Motherboard Replacement, Bumper: 3 단계, 이미지 3/3
    • Remove the eight 10 mm Phillips #1 screws.
  4. Rydis H68 Pro Motherboard Replacement: 4 단계, 이미지 1/3 Rydis H68 Pro Motherboard Replacement: 4 단계, 이미지 2/3 Rydis H68 Pro Motherboard Replacement: 4 단계, 이미지 3/3
    • Hold the front bumper and pull it off.
    • It requires a lot of force to pull the bumper off.
  5. Rydis H68 Pro Motherboard Replacement: 5 단계, 이미지 1/3 Rydis H68 Pro Motherboard Replacement: 5 단계, 이미지 2/3 Rydis H68 Pro Motherboard Replacement: 5 단계, 이미지 3/3
    • Pry off the back bumper by going around the entire top of the bumper with the metal spudger.
  6. Rydis H68 Pro Motherboard Replacement, Motherboard: 6 단계, 이미지 1/3 Rydis H68 Pro Motherboard Replacement, Motherboard: 6 단계, 이미지 2/3 Rydis H68 Pro Motherboard Replacement, Motherboard: 6 단계, 이미지 3/3
    • To access the motherboard, lift the top portion of the vacuum off.
  7. Rydis H68 Pro Motherboard Replacement: 7 단계, 이미지 1/2 Rydis H68 Pro Motherboard Replacement: 7 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to remove the four 10 mm screws holding the motherboard in place.
  8. Rydis H68 Pro Motherboard Replacement: 8 단계, 이미지 1/3 Rydis H68 Pro Motherboard Replacement: 8 단계, 이미지 2/3 Rydis H68 Pro Motherboard Replacement: 8 단계, 이미지 3/3
    • Pinch the two tabs together, shown here, to loosen the motherboard out of the vacuum.
    • Lightly pull on the USB connector shown to lift the motherboard out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jessica Alimonti
회원 가입일: 02/17/17
138 평판
안내서 1개 작성함
USFT-Lacy-S17S005G2 USFT-Lacy-S17S005G2 회원
Repair Café
4 회원들
안내서 10개 작성하였습니다
댓글 3개
This was GREAT.... Lots of pics :-)
I was able to pull the mother board without much trouble. Mostly scared of breaking the connections.
NOW???? Where do I buy the darn thing?
Please respond,
Robert
Robert Kilgore - 답글
Unfortunately, it looks like Moneual had some fraud issues and went under in 2014. It may be difficult to get your hands on replacement parts for the Rydis H68 Pro. =[
Richard -
where are the internal batteries CR2032 ?? I have heard that problems maybe due to internal batteries and not motherboard. Unable to get top off.
Do you know how to do a factory reset ? thank you. N. Tribley Oct. 23
naomi - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 1,272
