소개
If you need to replace or fix and component of the Ryobi P214 cordless drill that is on the inside cast, use this guide to access the inside panel.
필요한 것
Remove ten 13.5 mm screws from the drill casing using a Phillips #2 screwdriver to gain access to the interior.
거의 끝나갑니다!
결론
