주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ryobi D620H Motor Brush Replacement
필요한 것
  1. Ryobi D620H Motor Brush Replacement, Right Side Case Removal: 1 단계, 이미지 1개 중 1개
    • Turn the drill so that the screws face upwards.
    • Use the Torx T20 screwdriver to remove all nine screws.
    댓글 쓰기
  2. Ryobi D620H Motor Brush Replacement: 2 단계, 이미지 2개 중 1개 Ryobi D620H Motor Brush Replacement: 2 단계, 이미지 2개 중 2개
    • Insert the end of an opening tool between the right and left sides of the drill to pry the right side of the case.
    • Remove the right side case to expose the inside of the drill.
    댓글 쓰기
  3. Ryobi D620H Motor Brush Replacement, Motor Brush: 3 단계, 이미지 1개 중 1개
    • The motor brushes are located on the rotating armature of the motor.
    • Look for the large dark gray metal housing in the center of the body of the drill, this is the motor.
    • The armature of the motor by finding the chuck and the transfer gears, and then look at the other end of the motor. There is a small copper barrel (armature) that is likely colored dark gray from the carbon brushes rubbing against the armature.
    • On the top and bottom of the armature (small copper barrel), there are brass spring-loaded brackets holding blocks of carbon against the armature; these blocks are the motor brushes.
    댓글 쓰기
  4. Ryobi D620H Motor Brush Replacement: 4 단계, 이미지 2개 중 1개 Ryobi D620H Motor Brush Replacement: 4 단계, 이미지 2개 중 2개
    • Unscrew the brass spring-loaded bracket from the case using a PH1 screwdriver and remove them from the case and armature.
    • The motor brush will likely partialy self-eject from the brass brackets.
    • It is highly recommended to replace one motor brush at a time to not mix up the wiring.
    • Unscrewing the brush brackets is the same for both top and bottom.
    댓글 쓰기
  5. Ryobi D620H Motor Brush Replacement: 5 단계, 이미지 1개 중 1개
    • Pull the two connections (circled in red) gently from their terminals.
    • The longer white wire connects to the left side terminal and the shorter white wire connected to the brush connects to the right side terminal
    • Remove the composite shim under the bracket.
    댓글 쓰기
  6. Ryobi D620H Motor Brush Replacement: 6 단계, 이미지 1개 중 1개
    • Remove screws and disconnect the two terminals circled in red on the bottom brush bracket.
    • Remove the longer black wire that connects to the left side terminal
    • Remove the shorter white wire connected to the brush that connects to the right side terminal
    • Remove composite shim under the bracket.
    댓글 쓰기
  7. Ryobi D620H Motor Brush Replacement: 7 단계, 이미지 2개 중 1개 Ryobi D620H Motor Brush Replacement: 7 단계, 이미지 2개 중 2개
    • This process is identical for the top and bottom brushes as they are mirrored.
    • Remove the right-side wire from terminal. (The wire that connects to the brush).
    • Pull the brush out of the brackets gently. It shouldn't require much force.
    댓글 쓰기
  8. Ryobi D620H Motor Brush Replacement: 8 단계, 이미지 2개 중 1개 Ryobi D620H Motor Brush Replacement: 8 단계, 이미지 2개 중 2개
    • Place the new coil spring on the new bracket.
    • Slide the motor brush wire into the bracket and connect it to the right-side terminal.
    • Reconnect the longer white wire on the top brackets left side terminal by firmly and steadily pushing down.
    • Reconnect the longer black wire on the bottom bracket left side terminal by firmly and steadily pushing down.
    • Replace the composite shim under the brackets.
    • Screw both brackets down.
    댓글 쓰기
결론
You've successfully replaced the motor brushes on your Ryobi Hammer Drill!
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Jacob da Ponte
회원 가입일: 10/30/23
469 평판
안내서 5개를 작성함
UMass Dartmouth, Team 1-2, Petersen Fall 2023 UMass Dartmouth, Team 1-2, Petersen Fall 2023 회원
UMASSD-PETERSEN-F23S1G2
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 19
지난 30일: 66
전체 시간: 1,333
