주요 콘텐츠로 건너뛰기
Ryobi P202 Battery Contacts Replacement
필요한 것
  1. Ryobi P202 Battery Contacts Replacement, Battery: 1 단계, 이미지 1/3 Ryobi P202 Battery Contacts Replacement, Battery: 1 단계, 이미지 2/3 Ryobi P202 Battery Contacts Replacement, Battery: 1 단계, 이미지 3/3
    • The battery can shock you. Only touch plastic, non-conductive components.
    • Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
  2. Ryobi P202 Battery Contacts Replacement, Right Side Case: 2 단계, 이미지 1/2 Ryobi P202 Battery Contacts Replacement, Right Side Case: 2 단계, 이미지 2/2
    • Use a Torx T10 screw driver to unscrew all ten 13.5 mm screws from the drill casing to gain access to the interior.
  3. Ryobi P202 Battery Contacts Replacement: 3 단계, 이미지 1/2 Ryobi P202 Battery Contacts Replacement: 3 단계, 이미지 2/2
    • Gently lift the casing from the drill body.
    • Take the casing completely off the drill body to gain access to the interior of the drill.
    • The Ryobi P202 casing has Part #: 200690001
  4. Ryobi P202 Battery Contacts Replacement, Battery Contacts: 4 단계, 이미지 1/2 Ryobi P202 Battery Contacts Replacement, Battery Contacts: 4 단계, 이미지 2/2
    • Grip the battery clip and pull straight up to remove the metal battery contacts.
    • You can now clean the metal battery contacts with isopropyl alcohol.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Joseph Eckstein
회원 가입일: 04/07/15
1,596 평판
안내서 9개 작성하였습니다
Cal Poly, Team 17-6, Forte Spring 2015 Cal Poly, Team 17-6, Forte Spring 2015 회원
CPSU-FORTE-S15S17G6
4 회원들
안내서 10개 작성하였습니다
댓글 4개
You don't really need to take apart the drill. You can clean the contacts with Qtips by reaching into cavity. Use rubbing alcohol and long Qtips. Also you can bend the contacts back to normal with a pair of needle nose plyers.
TheAarowsmith - 답글
Doe anyone know where I can buy new battery contacts as mine has snapped?
dsstirrup - 답글
Re snapped contacts, I’ve found this part no. but no supplier yet:
“Ryobi Contact Plate holder 300001044”
Jeremy Twiggs - 답글
Does anybody out there know where to find these as mine has snapped also, not ready to junk it out yet.
Kevin Kleckner - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 30
전체 시간: 3,873
