소개
This guide demonstrates how to open the drill and remove the gear select switch. Removing the gear select switch does not require disassembling any of the internal electronics of the drill, but it is recommended to remove the battery to reduce shock hazard.
필요한 것
Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
Use a Torx T10 screw driver to unscrew all ten 13.5 mm screws from the drill casing to gain access to the interior.
Rotate the Drill 180 degrees so that the top is facing you.
Lift the level gauge out from the top corner of the drill.
