주요 콘텐츠로 건너뛰기
Ryobi P202 Gear Select Switch Replacement
필요한 것
  1. Ryobi P202 Gear Select Switch Replacement, Battery: 1 단계, 이미지 1/3 Ryobi P202 Gear Select Switch Replacement, Battery: 1 단계, 이미지 2/3 Ryobi P202 Gear Select Switch Replacement, Battery: 1 단계, 이미지 3/3
    • The battery can shock you. Only touch plastic, non-conductive components.
    • Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
  2. Ryobi P202 Gear Select Switch Replacement, Right Side Case: 2 단계, 이미지 1/2 Ryobi P202 Gear Select Switch Replacement, Right Side Case: 2 단계, 이미지 2/2
    • Use a Torx T10 screw driver to unscrew all ten 13.5 mm screws from the drill casing to gain access to the interior.
  3. Ryobi P202 Gear Select Switch Replacement: 3 단계, 이미지 1/2 Ryobi P202 Gear Select Switch Replacement: 3 단계, 이미지 2/2
    • Gently lift the casing from the drill body.
    • Take the casing completely off the drill body to gain access to the interior of the drill.
    • The Ryobi P202 casing has Part #: 200690001
  4. Ryobi P202 Gear Select Switch Replacement, Level Gauge: 4 단계, 이미지 1/3 Ryobi P202 Gear Select Switch Replacement, Level Gauge: 4 단계, 이미지 2/3 Ryobi P202 Gear Select Switch Replacement, Level Gauge: 4 단계, 이미지 3/3
    • Rotate the Drill 180 degrees so that the top is facing you.
    • Lift the level gauge out from the top corner of the drill.
    • The level gauge is Part #: 3000909
  5. Ryobi P202 Gear Select Switch Replacement, Gear Select Switch: 5 단계, 이미지 1/2 Ryobi P202 Gear Select Switch Replacement, Gear Select Switch: 5 단계, 이미지 2/2
    • Lift the gear switch upwards from the top of the drill head.
    • The gear switch is Part #: 341098001
결론
Joseph Eckstein
회원 가입일: 04/07/15
1,596 평판
안내서 9개 작성하였습니다
Cal Poly, Team 17-6, Forte Spring 2015 Cal Poly, Team 17-6, Forte Spring 2015 회원
CPSU-FORTE-S15S17G6
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 836
