주요 콘텐츠로 건너뛰기
Ryobi P202 Magnetic Tray Replacement
필요한 것
  1. Ryobi P202 Magnetic Tray Replacement, Battery: 1 단계, 이미지 1/3 Ryobi P202 Magnetic Tray Replacement, Battery: 1 단계, 이미지 2/3 Ryobi P202 Magnetic Tray Replacement, Battery: 1 단계, 이미지 3/3
    • The battery can shock you. Only touch plastic, non-conductive components.
    • Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
  2. Ryobi P202 Magnetic Tray Replacement, Right Side Case: 2 단계, 이미지 1/2 Ryobi P202 Magnetic Tray Replacement, Right Side Case: 2 단계, 이미지 2/2
    • Use a Torx T10 screw driver to unscrew all ten 13.5 mm screws from the drill casing to gain access to the interior.
  3. Ryobi P202 Magnetic Tray Replacement: 3 단계, 이미지 1/2 Ryobi P202 Magnetic Tray Replacement: 3 단계, 이미지 2/2
    • Gently lift the casing from the drill body.
    • Take the casing completely off the drill body to gain access to the interior of the drill.
    • The Ryobi P202 casing has Part #: 200690001
  4. Ryobi P202 Magnetic Tray Replacement, Magnetic Tray: 4 단계, 이미지 1/2 Ryobi P202 Magnetic Tray Replacement, Magnetic Tray: 4 단계, 이미지 2/2
    • Gently lift the magnetic tray from the bottom of the drill body.
    • The magnet is Part #: 303001015
결론
Joseph Eckstein
회원 가입일: 04/07/15
1,596 평판
안내서 9개 작성하였습니다
Cal Poly, Team 17-6, Forte Spring 2015 Cal Poly, Team 17-6, Forte Spring 2015 회원
CPSU-FORTE-S15S17G6
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 340
