주요 콘텐츠로 건너뛰기
Ryobi P235 Direction of Rotation Selector Replacement
필요한 것
  1. Ryobi P235 Direction of Rotation Selector Replacement, Battery: 1 단계, 이미지 2개 중 1개 Ryobi P235 Direction of Rotation Selector Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Push in both push tabs on the battery at the same time.
    • They are located below the green housing and are in the middle on both sides of the battery.
  2. Ryobi P235 Direction of Rotation Selector Replacement: 2 단계, 이미지 2개 중 1개 Ryobi P235 Direction of Rotation Selector Replacement: 2 단계, 이미지 2개 중 2개
    • Pull the battery away from the drill housing while holding in both tabs.
  3. Ryobi P235 Direction of Rotation Selector Replacement, Direction of Rotation Selector: 3 단계, 이미지 2개 중 1개 Ryobi P235 Direction of Rotation Selector Replacement, Direction of Rotation Selector: 3 단계, 이미지 2개 중 2개
    • Use a Phillips #2 screwdriver to remove the eight 16 mm screws that secure the housing.
  4. Ryobi P235 Direction of Rotation Selector Replacement: 4 단계, 이미지 2개 중 1개 Ryobi P235 Direction of Rotation Selector Replacement: 4 단계, 이미지 2개 중 2개
    • Use a T20 Torx screwdriver to remove the four 25.4 mm screws that secure the front of the housing.
  5. Ryobi P235 Direction of Rotation Selector Replacement: 5 단계, 이미지 2개 중 1개 Ryobi P235 Direction of Rotation Selector Replacement: 5 단계, 이미지 2개 중 2개
    • Open the housing with the data label facing up.
  6. Ryobi P235 Direction of Rotation Selector Replacement: 6 단계, 이미지 2개 중 1개 Ryobi P235 Direction of Rotation Selector Replacement: 6 단계, 이미지 2개 중 2개
    • Lift the internal components out of the housing.
  7. Ryobi P235 Direction of Rotation Selector Replacement: 7 단계, 이미지 2개 중 1개 Ryobi P235 Direction of Rotation Selector Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the gray plastic forward/reverse selector.
결론
작성자
2다른 기여자 명과 함께
Justin Godleski
회원 가입일: 03/19/18
295 평판
안내서 1개를 작성함
UMass Dartmouth, Team S4-G2, Saloman Fall 2019 UMass Dartmouth, Team S4-G2, Saloman Fall 2019 회원
UMASSD-SALOMAN-F19S4G2
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 27
전체 시간: 1,046
