주요 콘텐츠로 건너뛰기
Ryobi P235 Magnetic Tray Replacement
필요한 것
  1. Ryobi P235 Magnetic Tray Replacement, Battery: 1 단계, 이미지 1/2 Ryobi P235 Magnetic Tray Replacement, Battery: 1 단계, 이미지 2/2
    • Push in both push tabs on the battery at the same time.
    • They are located below the green housing and are in the middle on both sides of the battery.
  2. Ryobi P235 Magnetic Tray Replacement: 2 단계, 이미지 1/2 Ryobi P235 Magnetic Tray Replacement: 2 단계, 이미지 2/2
    • Pull the battery away from the drill housing while holding in both tabs.
  3. Ryobi P235 Magnetic Tray Replacement, Magnetic Tray: 3 단계, 이미지 1/2 Ryobi P235 Magnetic Tray Replacement, Magnetic Tray: 3 단계, 이미지 2/2
    • Use a Phillips #2 screwdriver to remove the eight 16 mm screws that secure the housing.
  4. Ryobi P235 Magnetic Tray Replacement: 4 단계, 이미지 1/2 Ryobi P235 Magnetic Tray Replacement: 4 단계, 이미지 2/2
    • Use a T20 Torx screwdriver to remove the four 25.4 mm screws that secure the front of the housing.
  5. Ryobi P235 Magnetic Tray Replacement: 5 단계, 이미지 1/2 Ryobi P235 Magnetic Tray Replacement: 5 단계, 이미지 2/2
    • Open the housing with the data label facing up.
  6. Ryobi P235 Magnetic Tray Replacement: 6 단계, 이미지 1/1
    • Remove the magnetic tray from the device.
결론
Paul Sousa
회원 가입일: 10/29/19
805 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S4-G2, Saloman Fall 2019 UMass Dartmouth, Team S4-G2, Saloman Fall 2019 회원
UMASSD-SALOMAN-F19S4G2
3 회원들
안내서 6개 작성하였습니다
댓글 한 개
Thanks for sharing, I was actually looking for these steps.
Mark Robert - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 298
