주요 콘텐츠로 건너뛰기
Ryobi P235 Motor Replacement
필요한 것
  1. Ryobi P235 Motor Replacement, Battery: 1 단계, 이미지 2개 중 1개 Ryobi P235 Motor Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Push in both push tabs on the battery at the same time.
    • They are located below the green housing and are in the middle on both sides of the battery.
  2. Ryobi P235 Motor Replacement: 2 단계, 이미지 2개 중 1개 Ryobi P235 Motor Replacement: 2 단계, 이미지 2개 중 2개
    • Pull the battery away from the drill housing while holding in both tabs.
  3. Ryobi P235 Motor Replacement, Motor: 3 단계, 이미지 2개 중 1개 Ryobi P235 Motor Replacement, Motor: 3 단계, 이미지 2개 중 2개
    • Use a Phillips #2 screwdriver to remove the eight 16 mm screws that secure the housing.
  4. Ryobi P235 Motor Replacement: 4 단계, 이미지 2개 중 1개 Ryobi P235 Motor Replacement: 4 단계, 이미지 2개 중 2개
    • Use a T20 Torx screwdriver to remove the four 25.4 mm screws that secure the front of the housing.
  5. Ryobi P235 Motor Replacement: 5 단계, 이미지 2개 중 1개 Ryobi P235 Motor Replacement: 5 단계, 이미지 2개 중 2개
    • Open the housing with the data label facing up.
  6. Ryobi P235 Motor Replacement: 6 단계, 이미지 1개 중 1개
    • Lift the motor and chuck assembly out of the housing.
  7. Ryobi P235 Motor Replacement: 7 단계, 이미지 2개 중 1개 Ryobi P235 Motor Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the gear case and sleeve bearing assembly from the inner case assembly.
  8. Ryobi P235 Motor Replacement: 8 단계, 이미지 2개 중 1개 Ryobi P235 Motor Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the cam shaft and motor assembly.
  9. Ryobi P235 Motor Replacement: 9 단계, 이미지 3개 중 1개 Ryobi P235 Motor Replacement: 9 단계, 이미지 3개 중 2개 Ryobi P235 Motor Replacement: 9 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Remove the metal pins on each side of the inner case assembly.
    • It is easiest to push the pin through the opening from one side and once enough of the pin is through, grab it with the tweezers and pull it the rest of the way through.
    • When reassembling, make sure the pin goes in straight and makes it out the other side, rather than going in diagonally and into the inner case assembly.
  10. Ryobi P235 Motor Replacement: 10 단계, 이미지 2개 중 1개 Ryobi P235 Motor Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the ring gear.
    • To help lift the ring gear out of the inner case assembly, wedge the spudger under one side, moving it up by a little, then switch to the other side and repeat until the gear ring is out.
  11. Ryobi P235 Motor Replacement: 11 단계, 이미지 3개 중 1개 Ryobi P235 Motor Replacement: 11 단계, 이미지 3개 중 2개 Ryobi P235 Motor Replacement: 11 단계, 이미지 3개 중 3개
    • Remove the two 8mm screws and spring washers connecting the motor to the inner case assembly.
    • Separate the two parts.
  12. Ryobi P235 Motor Replacement: 12 단계, 이미지 3개 중 1개 Ryobi P235 Motor Replacement: 12 단계, 이미지 3개 중 2개 Ryobi P235 Motor Replacement: 12 단계, 이미지 3개 중 3개
    • Use a soldering iron to remove the black and red wires connecting the motor to the trigger assembly.
    • Use the soldering iron to connect the new motor to the trigger assembly.
    • Make sure the red wire connects to the lead with the red mark on it.
결론
To reassemble your device, follow these instructions in reverse.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Paul Sousa
회원 가입일: 10/29/19
814 평판
안내서 5개를 작성함
UMass Dartmouth, Team S4-G2, Saloman Fall 2019 UMass Dartmouth, Team S4-G2, Saloman Fall 2019 회원
UMASSD-SALOMAN-F19S4G2
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 52
전체 시간: 2,715
