주요 콘텐츠로 건너뛰기
Ryobi P271 Drill Bit Holder Replacement
필요한 것
  1. Ryobi P271 Drill Bit Holder Replacement, Battery: 1 단계, 이미지 1/3 Ryobi P271 Drill Bit Holder Replacement, Battery: 1 단계, 이미지 2/3 Ryobi P271 Drill Bit Holder Replacement, Battery: 1 단계, 이미지 3/3
    • Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
  2. Ryobi P271 Drill Bit Holder Replacement, Drill Bit Holder: 2 단계, 이미지 1/1
    • Remove all ten screws from the drill's casing to gain access to the interior.
  3. Ryobi P271 Drill Bit Holder Replacement: 3 단계, 이미지 1/1
    • Using your hands, lift and remove the right cover of the drill body off from the left side and place it down.
  4. Ryobi P271 Drill Bit Holder Replacement: 4 단계, 이미지 1/2 Ryobi P271 Drill Bit Holder Replacement: 4 단계, 이미지 2/2
    • Remove the drill bit holder from the body of the drill.
결론
Carissa Keung
회원 가입일: 10/31/19
395 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S2-G6, Barthe Fall 2019 UMass Dartmouth, Team S2-G6, Barthe Fall 2019 회원
UMASSD-BARTHE-F19S2G6
3 회원들
안내서 10개 작성하였습니다
댓글 한 개
These instructions are utterly useless. Step 4 makes absolutely no sense.
Johnny C - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 4
30일 전: 21
전체 시간: 1,120
