주요 콘텐츠로 건너뛰기
Ryobi P271 Magnet Replacement
필요한 것
  1. Ryobi P271 Magnet Replacement, Battery: 1 단계, 이미지 1/3 Ryobi P271 Magnet Replacement, Battery: 1 단계, 이미지 2/3 Ryobi P271 Magnet Replacement, Battery: 1 단계, 이미지 3/3
    • Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
  2. Ryobi P271 Magnet Replacement, Magnet: 2 단계, 이미지 1/1
    • Remove all ten screws from the drill's casing to gain access to the interior.
  3. Ryobi P271 Magnet Replacement: 3 단계, 이미지 1/1
    • Using your hands, lift and remove the right cover of the drill body off from the left side and place it down.
  4. Ryobi P271 Magnet Replacement: 4 단계, 이미지 1/1
    • Carefully slide the magnet from its holder.
결론
Carissa Keung
회원 가입일: 10/31/19
395 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S2-G6, Barthe Fall 2019 UMass Dartmouth, Team S2-G6, Barthe Fall 2019 회원
UMASSD-BARTHE-F19S2G6
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 10
전체 시간: 396
